Aftermarket Steeringwheel
Hi ppl I was thinking of replacing my cup steeringwheel with an aftermarket wheel like a momo and was wondering if anyone off here has replaced their's and will my car pass an MOT as both airbags will not work and will I have an airbag warning light come on, on the dashboard? Thanks......
Gaz_
  Extreme mode
mine has a momo, passed an mot. Just put some resistors (pm edde for the values) into the loom connectors that connect upto the air bag, jobs a goodun, lights extinguish :)
Have a look at this thread
http://www.cliosport.net/forum/showthread.php?t=109205
Drivers airbag - There are two resisters you need. The airbags system works on a high and low pressure system so you need one resister for each line. If you remove the airbag you'll find 4 wires. One pair go from the orange connector to lines 6 and 7 on the cruise control/airbag connector. They are orange and grey in colour. They go to a black connector and exist the connector on the same colour lines. You can put the resister before or after the connector block though between the wires. These wires go into connections into the airbag computer in lines 4 and 29 (if you want to strip the center console off to save the weight/loose wires).
The other pair of wires go from the green connector to lines 9 (beige) and 10 (salmon) on the cruise control/airbag connector (Black in colour) then out of the connector on the same colour lines. These wires go into connections into the airbag computer in lines 5 and 10 (if you want to strip the center console off to save the weight/loose wires).
