Air bag light keeps coming on
  ph1 172 Black
It's like a intermittent fault. It comes on. Sometimes goes off after a min sometimes 20mins. Someone said could be wiring under seat. Anyone else got any views?
It is the wiring under the front passenger seat. Reach under and give it a waggle.
Mine comes on virtually every time it gets moved to let people in the back :rolleyes:
  172 ph1
Using the search feature gives:
"Look under both front seats.. You will see a grey plastic connector with a blue and a brown wire going in/out..
Cut the wires off the plug and solder them together.. ie blue to blue, brown to brown..
That should cure the problem"
  M2 Competition
Not seen that! Might go have a look in a bit, although be a bit of a pisser if you ever have to remove the seats...
  ph1 172 Black
Your right about wiggling the wires. Maybe when I get bored one day I'll have a go at wiring. Bloody Renaults and wires. My speaker wires are random colours the airbag sensor comes on when it feels like it and the fog lights don't work!
