AIR Con broken
Car  09 GIXXER 750!!!
My aircon has been broken for a while.
Went t have it regassed and its leaking.
Is there any common areas where it leaks on a 182?
Where is the condensor? Is it under the black panel with all the other bits? How would I tell if its fault. Would it come up as a fault code when pluging into the ECU?
No it wont come up as a fault. Get an A/C specialist to come round and top your system up. Tell him you think there is a leak - he will then run a green coloured chemical through the gas to determine were the leak is. The dye will show up at the faulty part.
The condensor is the A/C rad - situated in front of your water rad
RADS
AIR CON PIPES
