Air Con Question?
yea it's normal me rents Landy Disco V8 has air con and it's condensation around the unit that drips off after use dats wat ur puddle should be, make sure it's jus water tho anyfin else and ur in trouble m8, hope dat helps.
My work car (Vectra) creates a small flood after a long drive with the air con on so all normal yes.
Nice English there.... init
I noticed this on mine last week for some reason. Never noticed it before. Had to go for a drive with the aircon off to check it out! Got back, no dripping :)
Quite normal, if you look under the bonnet after a run with the air-con on you will notice that the air-con pipes by the off-side inner wing will be dripping wet with condensation.
