Air Conditioning Problems
Car  Clio 182 Turbo
I have a Clio sPORT 182 on a 04 plate, there is power to the digital interface and i can change the temp and fan power, but there is not air being blown out of the vents, also when im driving and i turn the temp up the is a slight bit of air wistling through the vents at the right temp but jus know power behind it, any ideas??
deffo not fuse, i used a amp meter and ther is deff power to the fan but no power so i think it maight be the fan motor!
its the resistor pack, very common issue. under the scuttle panel on the drivers side, held in by 2 small screws and has a big plug going to it. just to warn you these are expensive brand new from renault, might be worth trying cliospares
Definitely the resistor pack. I've had to replace mine twice! Exactly the same problem you're having both times.
