Air filter on a turbo? How important
  R35 GTR
I got some bbpt big green cone type filter, looks a bit max power to be honest. Is there any benefit of getting colder air into the inlet? There is no heat shielding around it, and i've also thought about closed air intakes.
  Lionel Richie
won't matter what you use really dave, at least you have a chrage cooler, i'd be interested to know your inlet temps
  R35 GTR
supposed to be 0-60 in 4.9 according to letstorquebhp.com
All down to driver skill though, I am slow at gear changes.
Fred, measuring temperatures is what i do best.lol. Why do you need to know these? What would a good one be? I borrow some toys from work to check all this out.
  Lionel Richie
it would just be interesting to compare your inlet temps to a normal 172/182
BenR is the engine geek, speak to him on whats best
Cooler temps are always good as turbos heat up air something wonderful, the lower you start off, the less heat your charge cooler has to dump. And keeping air temps at or as close too 40 deg which is the temp that det really starts to come a cropping, is important.
Filter solution wise, whatever suits your wallet and fits the bay, dont run a viper though as the filter area will be too small.
  R35 GTR
Ah ok, cheers. Did think the viper would be too small, could imagine the innards being sucked out of it and into the engine.
Will try and fabricate a heatshield as it gets so bloody hot in the bay.
stevo172-RWD
  clio 172 rwd
could i have a look at the sheild mate?im currentley doing the same thing! has the little bracket broken yet that holds the pipe which the filters on?mine snapped soon after i had it because they never reterned the weld under,thus causing it the crack!:mad: .
is you filter a cotton green?
  R35 GTR
yeh i think its a green cotton one. As for the heat shield, I'll model one in cardboard first, then get it welded together. Might get a discount if we both have one.:)
  Clio 172 mk2
Yep.....even more important on turbo cars
I'd be inclined to run one of those AEM filters which sits in the wing to keep things really cool.
