spanky2000
Clio 182
Hi, I know there are many posts on this but I'm still bamboozled! I've always had problems with these lights coming on but usually a quick fumble under both seats sorts it. Not now though.
Car has been sitting up for nine months, damp and mouldy. Changed engine and gearbox so lots of pulling at wires around engine bay.
I've checked for continuity across all block terminal connectors under both seats and all are ok. I've cleaned them all with switch cleaner also.
I suspect I may have an issue with the uch and the headlight washers. Does anyone know if the uch has any function with the airbag system too? Or is the resistor method a cover all solution?
Any help at all is welcome as NCT (Irish MOT) next week!!! Thanks!
