Airbag warning on clio 99 RT
Car  Clio 172 RS ph1
Hi again,
my mom's clio 99 RT has a airbag warning light,
its not always on, in a 10min ride its starting to warn after 2 min and turning off at random.
what can that be ?
thank you !
Daniel.
ok thanks i will search now, just now I tried to unplug the connector and put it a part again, still after 20 seconds its turning on again.
renault used to cut the wires and solder the connections i believe. I will double check for you as i dont want you to do it and it be wrong but im pretty sure thats what thay used to do.
This may sound obvious but dont mess unless the battery is off!!!! You may end up with a bag in the side of the head or a hole in the dashboard!! You can solder the wires together but dont forget to heat shrink them and fully insulate the wiring after! We assume the airbag hasnt been switched off on the passenger side!! ;)
ok thank you :) this friday i will do the work, get the tools and remove "-" from battery.
Thanks ! will update soon.
hello again, under the seat i have to 2 connectors blue and yellow,
well i soldered the wires but still after 2 sec from ignition its turning on.
