Aircon not holding gas
had the aircon regassed last summer after we got our cup , and this year its not cold. We were told when renault did there checks during the bronze service that it wasn't getting cold .
any ideas if there is a common failure point ? i am sure loads of people must have bits of aircon they have pulled off so second hand servicable parts should not be an issue as i image new from renault are a fortune ? or can the seals be changed if thats whats leaking?
or best to go to an aircon specialist?
  A special one.
Im sure an ac specialist can find the problem, they inject some die into the system then put there yellow glasses on and use there funky uv light.
sbridgey
  disco 4, 182, Meglio
Mine had a corroded pipe end so i just bought a new set of O-rings for a few quid and fitted the relevant ones. It was perfect after that. But yeah just take it to an A/C specialist, they will sort it out for you.
just want the aircon working as its there , especially as not many cups had climate , and the mrs said it was hot today
​give her her due , i came back from the gym at 6.30 in the audi with the roof down and the temp was 23 outside .
  Clio 172
Dealer should have the equipment needed. We did.
If the A/C is rarely used, the oil that lubricates the seals and pump doesn't circulate and the seals can perish. As it's a gas, it's hard to find leaks. As previously said, a dye is added to locate the source of the leak. Either your local dealer or an AC specialist should be able to sort it for you.
