Alarm Chirp
Is it possible to have the alarm on my 182 chirp when you activate/deactivate it. If so can I do it myself or is it a dealer mod?
IT IS POSSIBLE YOU NEED A BLEEPER FFOM MAPLINS ANND A DIODE TO STOP IT BLEEPING WHEN YOU INDICATE DO THE CONNECTIONS UNDER BONNET PICKING THE POSITIVE OF THE BLEEPER ON INDICATOR FEED WITH A DIODE IN LINE MOUNT IT SOMEWHERE IT WONT GET TO WET TRY THE FUSE BOX GOOD LUCK
[Edited by gibby883 on 16 January 2005 at 9:16pm]
Quote: Originally posted by gibby883 on 16 January 2005
IT IS POSSIBLE YOU NEED A BLEEPER FFOM MAPLINS ANND A DIODE TO SOP IT BLEEPING WHEN YOU INDICATE DO THE CONNECTIONS UNDER BONNET PICKING THE POS OF THE BLEEPER OF INDICATOR FEED WITH A DIODE IN LINE MOUNT IT SOMEWHER IT WONT GET TO WET TRY THE FUSE BOX GOOD LUCK
  Ford Fiesta
I asked the alarm fitter who fits them to some of the 182s at the import centre at Teesport, he uses this forum. He said no.
But if you wanna go adding bits like the guy says above then it will.
IT CAN BE DONE IVE BEEN FITTING ALARMS ON VEHICLES SINCE 1985 SO THERES NOT MUCH I HAVENT DONE ALSO I FIT THE POOR RENAULT ALARMS FOR VARIOUS LOCAL RENAULT DEALERS
Didnt really want to start pluggin things into it. Was kinda hoping the feature was available but needed to be turned on. I know with a lot of alarms these days you plug in a laptop, boot up the companys software and you can change a lot of features on it.
Ah well, it does do the bloody annoying 3 beep thing a lot so hey :)
