I have recently just picked up a new rb track car with 71k on the clock. It was run in SLS at Knockhill and I have got it back on to the road.
I’ve removed some of the stickers now and the plates are on.
oh and some paint thanks to Gally for that
Spec
Engine :
KTR Throttle bodies with 60mm trumpets
KTR Gen 90 ECU
KTR twin exhaust with decat
KTR Coil Bracket
KTR Pedal Kit
NGK spark plug
ITG Filter
Catch Tank
PM Solid engine mounts
Modified Alternator bracket with rose joints
13 row oil cooler with sandwich plate
Transmission :
Brand new LUK Clutch (less than 5miles)
Billet Lightweight Flywheel
KTR short shift lever kit
Brakes :
Red High Spec Brakes with grooved & drilled 285mm discs (less than 100 miles)
Mintex F4R Front pads
Braided front lines
Brand new rear calipers, Disc’s and pads
Carbone Lorraina Dot 4 Fluid
PM motorsport spec bullet stud kit with steel nuts
Suspension :
Bilstein B14 kit (less than 10miles)
Alloy top mounts
Whileline anti roll bar
Front strut brace
2 x rear strut braces
Body :
Complete plastic 4 performance widows expect front windscreen
Lifeline zero 2000 fire extinguisher system 2 x engine nozzles, 1 x driver side nozzle with external/internal cut off switches.
Cartek soild state internal/external cutoff switch.
Carbon door cards
Renaultsport cup steering wheel
Bonnet pins
Boot springs
Rear lifeline rain light
Removable front bumper on quick latches
Brand new Varley red top 30 battery
Wheels and tyres
15” team dynamics pro race 1.2
4 x toyo r888 tyres
Safety
OMP roll cage
Cobra Evolution Pro seat
TRS 6 point red harness.
Still some stuff left to do but progress is being made
Gaz
