Alloy Wheel help and offset
Car  Not got a car
will a:
Offset of 35 and a 100mm stud Diameter be ok for my 182 oh and a 7J width?
Been reading that higher the number of offset the more in the Alloy sit? is that correct?
So a offset of 35 should sit nice and wide?
Right ive just bought Pro race 1.2 in silver
35 offset, and 195/45/16 tyre for my 182, i could have a 205 tyre but im unsure if i will have problems due to the dif offset and how far it will stick out. (i think)
nope, they'll scrub like a fucker if you lower it
the lower the ET number = the further out they sit, on a 182 that is bad
you need ET40 MAX ideally ET45 (or anywhere between 40-45)
hum, maybe, i wouldn't though, ET40 at absolute max IMO
with ET35 your wheels will be 10mm further out EACH side, 20mm total width EXTRA
my 2118 are et37
the car's lowered and i don't scrub...
with 10mm spacers it scrub a little,i think you can go until et 32-35 without spacers and without scrubbing..
