Got one of these it has dedicated sub pre outs, is it best to use them or use the front or rear ones? anyone done this i think the sub ones will be ok but just want to check!
^ you sure - i was running the rears WHILE having the preouts from the HU for the fronts, rears and sub going to an amp - as i was useing the fronts and rears for the fronts - so i could still use time correction on the fronts with the amp bridged - if you get what i mean
But that is on the 7894rb, you can choose to have the internal amp on or off - i now have turned it off as it imporves SQ.
As far as using the sub pre out goes - use it - you can then control the sub level ect - and im not sure of the modle but i have heard that some moddles - eg the 7893 had 3 preouts - but only the sub was a 4v preout - not sure baout the 9815 tho
Mines the 9813R, but its pretty similar to the 9815. I havent got amps connected up to the front and rear outputs yet, but from what ive read in the manual, it tells you that you are able to run off the head units internal amp, or switch over to the pre-outs.
