Alpine HU fitting
Do these feed power from the ISO connector, or is there a seperate power connector... i seem to remember reading somewhere they have a direct connection to the battery?
direct to the battery (but that may only be on the 4x60w ones)
[Edited by Dink16v on 12/9/2004 10:18:28 PM]
Quote: Originally posted by JAMESSRICH on 09 December 2004
dont need to use the direct feeds unless your using the speaker out-puts!
ill be running 4 speakers off the head unit.
is the direct feed easy to do?
should be not so bad to fit - where the bonnet release cable goes through the bulkhead (goes through a biggish grommet) route it through there and then seal the wires us to make sure its water tight!
9835 power comes from the ISO block - unlike the old 9815 which had a separate lead.
Maybe its not so power hungry now because they added the DC/DC converter back in. Oh and its fused at 15 Amps instead of 20 like the 9815
(Yes Ive got / had both units).
