Few quick questions for all you knowledgeable peeps out there... ;-)
1. Im running two amps at the moment which dim the headlights to the bass... am I going to be damaging the alternator if it cant keep up, or simply draining the battery?
2. Would the alternator from a DCi be a straight swap, both in terms of fitting and wiring? Or if not the DCi, is there any other higher output alternator I could stick straight on it with no mods?
Cheers guys.
