Alternator and belt required for PMS air con delete
  clio 172
Alternator is seized which came with the engine. It has a PMS aircon con delete bracket.
What belt is required for this set up and assuming I just get a valeo alternator ?
Undecided whether to go epas , assuming then i would need a different belt again and do people run a cup alternator then , do they mount up differently ?
colesy
  172 182 197 E61 530D
I’ve gone epas and run a cup alternator setup. Seemed a simpler option for me. Can then run a 5pk847 belt as you’re only running water pump and alternator
I have the PMS aircon delete kit on my 182 and have fitted a cheapo RTX 110amp alternator, all working ok.
Can't help with the belt, unless you also have the PMS lightweight pulleys fitted, in which case don't do what I nearly did......swap your alternator in for the surcharge without first swapping the pulleys, doh!
If you do have lightweight pulleys it's a 4 rib contitech belt, which i got direct from PMS, £18.44 delivered, just to be sure I got the right one
