Alternator - battery Cable size
Tomo3292
Car  Clio 1.6 K4m
I'm going to make a new cable going from the battery to alternator, starter motor. I did not take the size of each before rushing to work this morning.
Anyone able to confirm the size for me please?
I would like to know this too, I need a new ring crimp is it 25mm by 10mm required?
I've installed a full new battery circuit in my track car mate. Battery relocated to the rear, runs through a 175amp mega fuse, then into FIA electrical cut off. From there onto longacre bulkhead connector.
I'm in the process of modifying my loom both parts, removed the old battery alternator circuit and cable and made my own.
I've used 25mm for the main battery Cable with m10 connections, then 16mm cable for the alternator with M8 connection.
