Amp and Sub not working!!!
  1.6 focus zetec....
HI all,
A few weeks ago my amp light came on red instead of green which i put down to not enough power supply and was going to buy a power cap, i came to have a look today just to see if by any chance the light had changed green and it has but......the subs still arent working! Anyone had this sort of problem before that can help me?
Kiza
  don't
remote cable maybe loose, rcas
have you checked all connections behind the headunit
if u have a voltmeter thing u can check which wires are giving the amp power and which arent
also double check the earth is ok
red light id guess meant the amp went into protection, id take it to a specialist so they can give it a good checking over
possible that a power surge has damaged some of the internal components
  1.6 focus zetec....
cheers lads, i have checked the connections on the amp and sub but not yet on the headunit as once you get my head unit out its hard to put it back due to all the wires
Kiza
  2005 Impreza WRX STI
all voltage and earth are ok if light is on!!! as bryan said its a protection light! u may have a speaker wire shorted to chassis somewhere or a speaker short circuit! remove sub and try diff speaker see if it works. it sounds exactly what happened to mine! output mosfet transistors are fooked on mine! best take it to ice experts mate! or get a diagram and check it yourself if ya competant?
  1.6 focus zetec....
ye am considering taking it to a specialist but am also considering a new install so i might have a crack myself..wish me luck all
thanks
hate to say, if the light is green and the subs are still not working they might be screwed...got to a local ice store theyll be able to check this out for you...
