Amp Frequency
Car  Skoda Fabia vRS
my amp has 2 options for frequency
its running 6x9s
either 70hz or 100hz.......which do i choose ?
Brun are sure you are not looking at the low pass filter, they seem to be very low i.e for subs.
no thats seperate
it has the filter off / low pass / high pass
this is a seperate switch
Yeh, Thats what I mean. When you select low pass on one switch you can alter the requency of the low pass with the other switch. I.E Low pass selected with the option of either 70 or 100hz.
Griff
o right, so it doesnt affect it unless im usin the low pass filter ?
what about the high pass ?
Yep only affects Low pass if Im correct. Perhaps one of the Ice experts can clarify this later.
Griff
Err need more info...assuming that there are no other switches on there, you must be able to choose full frequency, low pass or high pass output. The 70/100 switch will give you high or low pass at 70 or 100hz. If youre low passing to the 6x9s you want to put it at 100hz. If youre high passing to the 6x9s then make it 70 so you get the widest range possible out of them and it just protects them from the lowest frequencies.
If youre running a sub then you want it low passed at 70..
its just runnin 6x9s.....thats all
anywayz ive spoke to Dazz and your right about it only being for the filter mate
ive got the filter off so its fine on any settin
