Amp Problems
  1.4 Maxim (Breaking!)
Been trying to connect up my Amp for my sub, the earth & remote is connected & when i go to connect my inline power cable to the battery on the Positive, i get sparks and then the fuse blows on the cable, ive used about 6 fuses now and they keep blowing.
  MK1 Clio 16v
Must be wired up wrong then? Disconnect the earth on the battery before you connect the +ve, as this will prevent it from sparking. Then connect the earth and see if the fuse still blows.
Check connections at the amp end as well, check you have a good earth and that the amp isn't fooked.
  182 Full Fat
Make sure Positive and negative arond the wrong way like I did! That blew a few fuses when i did it by mistake!
Just been down to my car and did what you said & ok no sparks now but nothing happens at all, i got 2 amps and both don't work, ive tried all different amp fuses, the earth is good too, i didn't wire the remote in, it was in the HU when i got it is there a right or wrong place it could be?
you are putting the earth to the power and vice versa, try the other way round maty,
This is my setup
