Amp wiring...again
Alright
Ive found the grommet everyone uses. however how do you get your cable through that? Do you slice a new hole or something?
how do u locate the wire in the engine bay to get it connected to the battery once you have fed it through? can you get to it easily?
what did you use to make the hole bigger? like a screw driver in the end and just try stretch the hole?
chris if you follow the bonnet release cable from the release, you can see exactly where the cable goes in...
i found that, but how do u locate the amp wire inthe engine bay after you have fed it through the hole? will i be able to see it easy enough?will i be able to reach down and grad it in the engine bay?
