Amp Wiring connectors
you're not supposed to use pliers, this is a common mistake, that will flatten the connector, you're supposed to use crimers, this will force the middle down and grip the cable inside
i'd get some new connectors if i was you and redo it with the correct tools
not the best pic, but it gives you a clue as to what they look like
Ok I'm looking at one now, I see the split - so you use the crimpers to crush them lengthways?
yer i got the top ones cost somet like 2-3 quid , n makes life alot easy strippin wires and crimpin
Ok just so I'm 100% sure on the way to crush.
Picture a:
this way!
Picture b:
that way!
Picture c:
Dave's way!
I would've thought that would squash it flat just like pliers.
Orrrr, the split is where the metal begins... ahhh it all falls into place.
Thx Bryan.
it yer using pliers , use the sire cutter part , but add a nail (or somet) at the tip (grip part) so they dont cut through it
