An Aircon Question
Car  CB1N
I have regassed my aircon so it works perfectly when set to cold. As far as heating is concerned hot air is coming out at all times except when car is started. It blows cold air until the engine coolant heats up, no matter whether ac is on or off.
What I want is to have the heating the moment the engine is started, if possible. Is this normal or it can be fixed?
Also the interior sensor fan is buzzing my ears off so it prolly needs changing....
Ok so u r saying that AC can be used just for cooling but not for heating, and that for heating to be effective, the engine coolant passing to the heater matrix must be hot.
I am asking because I can get hot air straight away (no waiting for engine temperature to rise) after cold start in my Pug 307, just by using AC. Dont get me wrong I am satisfied with how everything works in my Clio, just wanna make sure everything works as it should...
Thx
im not sure as i didnt have it done, recently bought the car you see and was told it had been done
Is the aircon compressor working? Pop open the bonnet, start your engine, then press the aircon button if it's working you'll hear a click from the compressor. If you don't hear anything then the gas has probably leaked out as it only works if there is enough pressure in the system.
Click? If it's anything like any of my old Clios it sounds more like someone taking a lump hammer to the block!
OP - Air Conditioning is purely for cooling. For heat, you need the coolant to get up to temperature.
yeah don't press the ac button if you want the car to get warm lol
Click, clunk, clonk whatever :clown:
