Quote: Originally posted by blink172 on 07 January 2005
Id check these items:
The parcel shelf (im sure mine rattles) took it out and it still did it
Check/oil the locking mechanism (Courtesy of Jon R) did this
Add some foam to the centre passenger belt in the roof to stop that shaking did this
Check/oil the joints where the rear seats clip into. will try
Fill the entire rear of the car with a mixture of eggwhite and PVAglue (ok i wouldnt do this one) wont try LOL
Ian
Like i said i think its the plastic trim that covers the boot as whilst the wife drove i pushed this and the rattle stopped !!, i dont know what it is though as i have had it off before and put foam all around it, i think its the clips themselves (the ones that fit into the metal
Quote: Originally posted by thumper on 07 January 2005
Are you sure its the boot Ive got a 12ver in my 1.2 16vavler and the only thing that rattles at the moment is the quarter panels.
However what I did do was to remove the original carpet and replace it with 5mm mdf with some thick lounge carpet which also helped a lot
yeh its deffo the boot, as i was sat in it last night and heard it, anyway had the panel off again, and put foam around anything that moved and put bluetack on the clips that hold the panel on and covered everything else in grease, then went for a drive and its stopped the noise "woooohoooo"
