annoying rattle in door pillar on drivers side
As above anyone know how to remove the door pillar (plastic bit drivers side) so i can some how get rid of the really annoying rattle
cheers
matt
is it like a really high pitched rattle if so its where you adjust the height of the belt
almost like a clickin sound?
Matty if you open the door, its the J/L shaped plastic trim on the door, make sure all the clips are on properly, make sure none are broke.
I took my door card off the other day and secured all rattly bits, but still the rattle persists as if it is indeed coming from the B pillar.
Can you be more specific about fixing this as it's doin my nut in. Mine's more of a dull hollow rattle
My car has same rattle, only when my window is right down. When i put it up so its down all but an inch the rattle goes away.
