another full lock problem
Car  megane 225
3 weeks on owning an 03 plate 172 and started to just notice this.
On full lock in rither direction there is like a grinding whirling noise. Also can smell a bit of burnt rubber?
Obviously it must be something rubbing on the tyres i would assume.
Will take it into renault to get checked out, i realise alot of people have had this problem but what has been the cure for you all (if any?)
The wheel arch liner is probably become unattached from its clips take the wheel off and check it
as above, if its standard, and not lowered etc then something has to have come unclipped, and most likely just needs a good old fist and thump to clip it back in
