Evo 8 MR
This has been ongoing since I fitted the coilovers at a silly low height (or lack of) with rather extreme camber.
However that's all sorted now had a full setup etc but the box is still leaking (albeit only slightly) from the n/s driveshaft.
There is no visible damage from the outside and I'm led to believe it's a diff seal if that's the correct one or not I'm not sure but I've spoken to a specialist of who it is booked in with on Thursday.
I'm just wondering for those who have removed the shafts before and know the parts surrounding it etc can confirm that if this is the likely cause of the leak.
I've PM'd BRUN the parts guy and he confirms this may be the part I need but cannot confirm for sure whether they do these for the Clios.
May also be worth noting that it doesn't leak whilst staionary but there is always oil on the surrounding area on the box by the n/s shaft and is dripping so I believe it only leaks whilst it's moving.
Any help appreciated.
