172,Valver
Had my Ph2 172 02 plate for a month now and the speedo has decided to start playing up.
So far I've replaced the original sensor in the gearbox with a used 1 from local specialist/breakers and it worked sometimes when over 60-80mph then all the way down to 0 again although slightly bouncy from 20mph down.
Went and bought oe item from Renault and it still hasn't fixed it. I've checked for obvious breaks in the loom and can't seem to find any. Checked loom going into back of clocks all seems ok.
Finally done the test on the dials and they go through sequence fine.
I've searched all over and can't seem to find another thread with this problem.:S
Al
Al
