Hi,
I know there are quite a few leaky sunroof threads but I have a specific question. On a mk 2 clio how should the water drain from the rim around the sunroof glass to the drain that you can see if you lift the sunroof fully.
Water just seems to collect around the rim of the glass on mine and there is a wet patch on the roof.
Is the water collecting in the rim normal or should it drain to the trays under the sunroof?? Hope this makes some sense!
Cheers Dave
Cheers Dave
