SimonNOS
What they mean is to use coolant specifically for mixed metal engines. This is to avoid the coolant acting like a electrolyte and actually promoting corrosion internally. Use a Ethylene Glycol antifreeze and check it is suitable for mixed metal use, also dont mix different types in youre engine.
If you change yours and find the drain plug on top of block (top right under exhaust manifold - suppossedly) let us know, cause I couldnt locate it.
Alex M
