anybody good with lights... BOB rte...
Car  Lupo Gti
right, ive just brought some new fog lights for my 1995 clio 1.4 RT, as the old ones were mouldy nd were cracked, any way put the new ones in , connected them all up, and nethier of them worked, bot the old ones did, and i keep disconnecting the old one witch works and putting the new one in and it dont work, the annoying part is that the fog light unit itself has exactly the same part number etc as the old ones i took off, i need help!!!! please...
cheers
LMS
Put the old bulbs in and see what happens, If they dont work it sounds like a possible problem with either the plug or gremlins.
Sparky Dave
Silly question but have you checked to see if there are any bulbs in the new lamps ? most new spot lights dont have em in. Could you have blown a fuse ? Is the wiring at the back of the lamps ok ? Is the wiring loom which carries power to the lamps from the main loom ok ? have you shorted the wiring & possibly burnt your fog light switch out ? get yourself a voltage tester & do a couple of checks.
have a look and let us know.
