Anybody use an Apple AirPort Express Base Station
I'd keep your Netgear and just join that to your network if all you wanna do is play music to it via iTunes?
Otherwise, you'll be in bridge or double NAT hell..
Tom
  EV (s)
Im using mine as multiroom audio and a wireless printer extension.
Works great.
  Megane R26 + 182
My net gear dont reach my new room so im going to have to get a telephone line in there and use it as a router, Why will i be in double NAT hell, and what the devil is double NAT? Many thanks
If you get a phone line in there, you'll still need to move your Netgear.. as you'll need an ADSL modem (the Airport isn't one). You can't connect to the same broadband connection by just plugging in ADSL modems, either.. you can only have one.
If the wireless reach in there, you're going to have a problem.. unless you can put the Airport in between the two (room and Netgear) and use it as an extension? (I *think* the Netgears can do WDS, but depends on model)
Or, have a look at Homeplug stuff - then you can extend the network to that room, plug the express into that homeplug.
