Anyone any experience with a HELIX or similar clutch?
Car  Range Rover Sport
Think I'm going to swap the clutch soon.
From previous cars a Helix 'Organic' was a slight step up from OEM, is this the case with the clio too?
Anyone any experience with said clutch or similar?
I do like the feel of OEM however I have had mega heavy clutch in previous cars but I don't see the need for a 'paddle/twin/double' in the clio.
Any info would be great.
Car standard? Then OE is perfectly fine
Yes, I'm aware OEM is fine. However while swapping I feel why not 'upgrade' while its being done?
But as you say I'm confident a standard one is fine for most people but as i'll be swapping for piece of mind, would be silly not to look at 'improving' it if I can.
they're pretty much off or on, even with organic plate, horrible to use in traffic
You're back!! .......*whispers quietly* Whiteline.
Food for thought I guess, don't mind it being pretty bad in traffic as I have used a lot worse in the past, is it worth it for 'track' purpose?
It will do your head in eventually.
You say that, but apart from on and off the tailor I cant see it being a huge 'bore'?
However I do like the fact I would/could be future proofing it for later engine modification?!?!
I'm in two minds, I guess I can mull it over the next few weeks...
Depends how often you sit in traffic or need to do hill starts lol.
Paddle clutches are even worse, feel like putting in a whiplash claim after road use.
I don't sit in the car much, let alone traffic lol.
Yes I know what you're saying though.
if you are staying under 200lb/ft no point, there is no 'upgrade' as the standard is the best you can get for that power really.
A helix paddle clutch with a valeo covet plate feels ok to me and ok in traffic, yes a small judder on pull off but some thing that easly you can get used to
I had the HElLIX organic kit bought from k-tec, but due to some other problems I had to change it after 30k. But it felt nice, obviously not that user friendly in trafic but I got used to it and loved it. Coupled with full engine mount upgrade and poly pushed dogbone it really sharpens things up.
Why not upgrade?
Because it will be harsher to use and wont last as long.
Its not that the standard clutch is "ok" for the standard car, its that it is the best possible one available.
Only exception being if you are REALLY hammering it, ie actual racing with monstrously un-mechanically-sympathetic gear changes as it is possible to delimaminate them in those circumstances in very extreme cases, but you would never do it in normal driving or trackdays etc.
