Anyone Handy with VBA for Excel?
The Boosh!
ClioSport Admin
Car  Elise, Duster
If so would you mind PMing me your e-mail address so I can pick your brains?
In short i'm wanting a macro to activate as soon as a certain value is celected.
IE if cell a1 = 1 I want the code i've wrote to run.
Too busy to help out, but try googling worksheet_change event. Should do what you're after or lead you on to something that will.
You have gone up in my estimations symondo!
HTML:
Private Sub Worksheet_Change(ByVal Target As Range)
If Range("a1") = "QVN" Then
    Rows("5:7").Select
    Selection.EntireRow.Hidden = True
    Range("A1").Select
Else
    Rows("5:7").Select
    Selection.EntireRow.Hidden = False
    Range("A1").Select
End If
End Sub
I know it's basic but i'm still learning, but at least it works :D
ffs its still not right. It runs the macro no matter what selection I chose on the worksheet, I only want it to focus on the one cell
record the marco?
macros hurt my brain tbh
Are you sure that a macro is what is required to do the task
Yes it needs to be programmed into the VBE. You cannot record it.
It's frustrating because I can do most things in the VBE, but i've never used the worksheet Change event procedure, and im not sure of the parameters i need to set for what I want to do in this case.
Done it. I had to dimension a variable and add a few more lines.
Dim KeyCell As Range
Set KeyCell = Range("F10")
If Not Application.Intersect(KeyCell, Range(Target.Address)) Is Nothing Then
If KeyCell.Value = "QVN" Then
Rows("25:26").Select
Range("f10").Select
Else
If KeyCell.Value <> "QVN" Then
Range("f10").Select
End If
End If
End If
End Sub
Thanks anyway everyone. I now know how to PM in the future :p
I have to use it most days at work mate for some annoying and complex stuff. But I do use google to help me a hell of a lot.
