Anyone running carbs or throttle bodies?
  1996 Valver
May be getting a spare engine I can work on as a spare, thinking of doing some type of convertion, turbo's sound to expensive.
What have people done to theirs?
  1996 Valver
Sorry just realised what I have put at the top "May be getting a spare engine I can work on as a spare"
You all know what I mean!
throttle bodies are availale for 172 / 1.8 16v / 2.0 16v
we are running a 172 on bodies and are developing another kit for the Clio V6 due to be ready in 6-8 weeks.
/y0z
  Clio 1.8 16v
i was interested in some throttle bodies for my valver but couldn't find any info on them. does any one know where to get them from, price, and power gains? cheers, chris
All you had to do was ask ;)
i can tell you about the different options for every engine and the performance effects.
There are a few combinations for each engine, but invariably the best solutions which give the best power cost the most.
Gains on a stock 1.8's arent great for the money, they dont top out at much more than 170-175bhp for several reasons, plus you have to get a custom rad to lower the upper height limit of the rad so you can run a decent filter/inlet tract lenth. Its a much much better modification to move to 2ltr power and run a few simple modifications for 180+bhp and alot more torque.
PM me for any information required.
  1996 Valver
Thanks Ben
You seem to be the man to ask for technical questions, do you work for a tuning company? or are you just stato on engines?
  MKIII 138
breaking it down on a 172cup you need omex ecu, carbs, exhaust and wiring is this correct.
also if carbs are cheap (which they are) to buy as a set, then why are the convertions upwards and beyond £3,500 ?!
  20VT Clio & 9-5 HOT
throttle bodies are better than carbs! more expensive, but better!
you will need cams, pulleys, headwork, few custom bits and bobs including inlet manifold, also may need injectors, hi comp pistons, steel crank etc, depending how far you want to go, as well as the TBies, management, rolling road time, labour!
gets pricey!
Pat_986 said:
Thanks Ben
I run AngelWorks Technologies, a tuning company, and specialise in induction tuning, engine and heavy flow development.
On a 172 to run carbs you'll need a slightly inlet manifold to fit DCOE's, then you'll need AT LEAST a set of 45's which arent cheap new and not really available s/h as the factory has been on strike for a couple years and jsut started production again.
You will need to use the std ECU to control the ignition, or swap to an ignition only Omex setup etc.
You will need to change your fuel system to run a low pressure carb setup, as it stands you cannot run carbs on your fuel setup.
And lastly, once its all running, it'll be a poor quality drive at anything but 50-100% throttle as that is the compramise of carburetion, the fueling stages arent great at low air speeds.
  Clio 1.8 16v
So what would you suggest i do? go for a set of throttle bodies, or go turbo conversion. was thinking of a loan of about £5000 to speed the old valver up a bit.
£5k wont get you much in the way of a worthwhile turbo conversion, but it will get you a very nice NA engine.
I would jump straight to 2ltr first, and fettle with that, 1.8's are far too limited unless your prepared to re-engineer the engine at rather large cost.
I've got a few tricks up my sleeve so just PM me if interested.
  MKIII 138
why hasnt anyone mentioned and i may add never do offer the option of supercharging ??? its cheaper than a TB or turbo conversion and can offer anthying from a simple 30bhp to 80bhp depending on how much you wanna spend, theres no lag either so it suits at least the 172/182 and their instant throttle response. it can be mapped to come on at any point of build up.
before people spout 6k for converision i may point to the Jackson superchargers being installed and running VERY nicely on Civc type R`s with around 260bhp and there mindblowing quick.. a guy ive met recently had looked into this in full and 3.5-3.8k was buying and fitting ! not bad at all.. probably wont happen on the clio though as its a silly engine.
be nice for angel works and GDI or someone to do a converstion
  Lionel Richie
why is it cheaper??? who pays the development cost??
why do you think turbo/TB conversions are expensive?? low volume, low production
it'll easily be over £3K to charge a 172
I've looked into it comprehensively, and the option is always there for people, its not a problem to do, however its far from cheap.
Firstly Jackson Racing offer kits to solve every peice of the equation, they started and sole mainly in these kits, hence they have MASSIVE purchasing power when it comes to buying chargers, they can kick out tens to hundreds to kits worldwide a month, and economies of scale are much better.
The main problem they have solved is that the honda ECU has been cracked by a billion people and can be used basically as a standalone item so you can map it to any paremeter. The Renault siemens ecu has been cracked, but only a few people have access to the software, and can afford to pay for the licence to the software (only worth it if you kick out alot of chip's or kits etc). The problem we face is that the std ECU is not boost aware, so running boost through the ECU will simply lead to destruction as it cannot physically see the upper limites of manifold pressure beyond that you would see say in the netherlands which is slightly below sea level.
This mean for one off builds its easier to run a new ECU, which costs, and a charger new costs over £1000 depending what you go for. If you use a roots or lynsholm (positive displacement) then you dont have to run an intercooler, but you'll have to fabricate a manifold to adapt the charger outlet to the engine, and you'll need a new throttle body as its easier to run a cable throttle than try to map a FBW throttle body.
Jackson Racing are able to pump out hundreds of manifolds for their kits, which would be cast items, but setting up a casting takes thousands in making the mould and batch casting runs of say 30 minimum (foundaries dont want ot be bothered with small runs, setup time is too long).
If you can a centrifugal (turbo type) compressor, outlet temps are high (100c+), and you'll have to run an intercooler, which is additional cost, or water injection etc etc.
THen there is finding the space to drive the dam charrger (have a look and see if you can spot anywhere, not many people want to dump PAS/AC to have a charger.
Sorry for the rant, but there is super large amount of work and fabrication to do, so costs would be (for a system that is worth it at about 250-300bhp) nearing £8-10k
Cheap, i dont think so.
YOu could slap some half arsed system together running a 5th gen minicooper S charger, but then your limited to about 220bhp, and you still have to fiddle the ecu.
yea, i've won for the last 7 years.....................*in my mind* (need to have seen Eddie Izzard to get that) lol
