Are 182 xenons plug & play on the trophy?
Aslong as you have all the ballasts and starters mate, then yes they are.
The ballast would normally come with the headlight unit though right? Do you know if 172 headlights are exactly the same units?
I dont know how true this is but i have been told that if you have ABS the wiring loom is there for the headlights and its plug and play.
The headlight wiring is ment to be in the ABS wiring or so i have been told but i will take that with a pinch of salt
If they're 182 xenons yes. If they're 172 xenons yes, but you can't plug the motors in. I just left mine unplugged.
Zenons by law must be self leveling and be fitted with a washer system see all 182's fitted with them. So you could end up failing your MOT if you fit them most garages dont know this or decide to ignore it (the one i use does) but dont sell/throw your standard lights away as you might need them for the MOT. They are plug and play other than this.
The previous owner has plumbed in washer jets but he said something about he couldn't get the pump sorted. I think I will still get them anyway if they ain't to expensive...
