Ast top mounts
What are the maximum amounts of caster and camber that can be obtained from the top mounts? And I'm assuming that these maximums are at adjacent angles so that setting them in between both will give half the max caster and half te max camber?
Not sure about camber with AST top mounts, as just use for caster, you'll get (on a 172 CUP) 3.2 - .5 degrees castor with these. 1.5 - 1.8 on top of the standard 1.2 -.5 thereabouts.
Correct about amounts it you use for both camber and castor.
Thanks for that, what do you use for camber then on your car? Slotted holes in struts? Camber bolts? or modified wishbones?
