Attaching Carbon Fibre Mirror Covers!?
Car  Clio Dynamique
Im getting really annoyed as whatever i try and use to stick them on it doesn't work and they just come straight back off, best method from people who have fitted them before? Cheers
Clean both surfaces with a degreaser or some sort of alchohol solution. Let them dry, then use some silicon sealent (unibond) to stick the caps to the mirrors. Make sure you don't put the sealent right up to the edge otherwise when you push the caps on it'll go everywhere!
Use some masking tape to fix them in place and preferable leave em for 24 hours. If the fit round some of the edges isn't perfectly flush, use some thick double sided tape to help 'push' the edge out a little. Obviously you'd need to do this before you bond them on!
Hope this helps :)
Buy Tiger seal, its for holding on side skirts and body parts etc. That stuff will hold your granny down. Always do it in a dry place pref warm too, even go to an indoor car park if your struggling, there you will have good light too :)
