Attention all Wii Owners....
whe i had it at me mates we have it on the stand above the tv...
now im back at home... its blue tacked neatly under it... but to the bottom of the actual frame of the screen.
makes no difference as long as you let the Wii know where it is...if you put it above the tv but in the setting it thinks you have it under the tv it goes all over the shop...
mine personally is under...
my tv is on the wall, and the sensor is bout metre under it on a stand, still works perfect
anyone got wii play? if so, if u use the control like a gun on the shooting one.... is it accurate... i find if i aim over the top of the control... it shoots above it... but then i guess you use the point on the screen more.
I have mine just below my plasma.. works best that way.
Wii play is pretty accurate i feel.
Mine is pretty spot on as far as I can tell. I'd notice if it were out when playing Zelda.
Nope, not attached, although if I was I would just bluetack it.. not using those pads you get with it..
its a IR light, you dont even fecking need it.
any ir light source works, my mate is in the process of making his LCD with a built in sensorbar with higher IR output.
