The drivers side xenon stopped working, so changed the bulb and igniter and still doesn't work, it doesn't seam to be blowing fuses so really don't no what it is, everything else in the headlights works, sidelights etc
Ballast pack is most likely to be the cause then chap. When they die due to water ingress they are common for banging the fuse to that specific dipped beam circuit.
Bring it in if you want it confirming as it could also be a short to positive also (ballast pack is my guess though).
