182
Hi
Once again thanks to Auto Finnesse for the two samples "Ultra Glaze" and "essence wax".
Managed to test this on two different cars in two different conditions, please excuse the pictures its really hard to get a close up lol
Yesterday thanks to Badbuzz2 he gave me his 200T to give a good clean and test the new products
instead of putting 55 pictures of the cleaning process i have captioned the few around the new products (another thread with the rest in to follow).
So ultra glaze gave it a bloddy good shake as it had seperated then popped it open and got hit with the smell of furniture polish.
I had washed, iron out , rinsed , de-tar'd , rinsed , clayed , washed , dried , then Trippled and was left with this
It was hot yesterday so was a bit nervous of using glaze as it says not to let cure and wipe away excess .so i put a pea sized bit on a pad and done small areas which was applied then wiped off after 10 seconds.
Then once wiped off it added to the gloss massively i found which on a dark colour car is needed.
Very impressed.
Onto the wax "essence" it smells like a sweeter version of temptation, it is very very soft i found.
Only problem i found with essence is you cannot see where you have applied as it seems to dry clear! but goes along way, one dab on an applicator done the whole of the spoiler easily. As you can see in the picture you can't even see i have applied it
Due to the warmth i only let it cure for a few mins and it came off with ease probably the most easy off AF wax i have used.
Continued to do the same on the whole car and this is the result.
Onto the 182, bit cooler today and overcast so whilst i had a spare hour i thought id give the bonnet a go.
Started off with this
Shampoo'd with lather.
Rinsed and dried
Three Pea sized blobs of glaze on the applicator done the whole bonnet.
Left glaze till it was stogie to the finger but not dry, wiped away to give a great wet look
Wax was only two dabs to the pot to cover the whole bonnet, but once again the pics do not show.
I left it today for 30 mins before removing in which was really easy to get off. So it Buffed off to leave an awesome shine! better than Ilussion imo.
Bit of beading
Thanks again Auto Finesse
Very impressed.
Rinsed and dried
Bit of beading
