Auto Lights Not Working =(
Car  Renault Clio Dynamique
Righty folks I really need your help with this one. Tonight my auto lights were working when I was heading to play footie, parked the car up and when I came back out after I started the car and no auto lights :( I've checked that the dial on the stock is in the right position and everything but it still not working.
Anyone got a clue as to what's happened and how I can attempt to fix it?
Your help is really appreciated :D
I'm assuming you've tried turning it on manually. If you turn your key so that you have power but not with engine switched on. Then twist the stalk from off to sidelights only twice, you should then hear a beep. If they aren't activated from that then its probably a sensor problem... fuse maybe
Crisis averted folks! A quick search brought up several topics on how to fix it.
Sorry for the silly post :D
