Autoprotect warrenty anyone used them?Sensor fault
Hi guys, bought a clio recently and it now has an engine fault, box with zig zag and emmisions light and wont rev past 3k "safe mode" i presume.
Anyway, under my warrenty it seems to say it covers most things i think its either lambda, throttle body or something along those lines.. Would you say from the list of covered parts in the link they would be covered ?
Fuel system [diesel and petrol]
Carburettors, automatic choke, lift pump, mechanical or electrical fuel pumps and tank sender unit. Fuel injection system Throttle body, airflow meter, idle control valve, cold start valve, warm up regulator, overrun cut off valve, throttle potentiometer, fuel accumulator, pressure regulator, map sensor [except injectors and heater plugs].
Electrical system
Starter motor and solenoid, including preengagement mechanism and bendix drive, alternator/diode pack, coil voltage regulator, window and sun roof motors, electric window switches, sunroof switch, centralised locking, heater fan motor, indicator flasher relay, distributor, front and rear windscreen wiper and washer motors, electronic ignition amplifier, thermostatically-controlled radiator fan motor, horn and multi-function stalk switch. Engine management [ECU] Engine electronic control unit.
sounds like it, you just never know with these companys!
just get them out to it, dont say what you think it is to them!
I havent just told them exactly what happened they said, take it to a garage, get them to diagnose the fault, then get them to give us a call before commencing work on it.
