172 ph1
right...heard something fall to bits and fall down hitting a few things in the engine bay while driving the other day, when i pulled over the engine was making a horrific noise! got it home and after an inspection found that the outer bit of the idle pulley at the bottom of aux belt has came off? a mate thinks that the bearings would have collapsed causing it to come off and therefore make this noise....so basically ive seen them around for 70 odd quid (belt, tensioner & idler) is anyone cheper than that and do i really need to change the tensioner as i could buy the belt and idle from gsf for about 40 odd quid?
cheers
cheers
