Afaik it runs the coolant pump and power steering pump as well as the aircon compressor . Someone will probably come along an give you more info . I might be wrong lol .
not using air conditioning wont make much difference,
its stipping at the same rate as the revs, reducing the load might made a slight difference, but i would risk it
also rubber perishes at a standard rate,
and if it snapps, it will cause havok with everything in the engine bay,
