Ball joint question
  Clio 182
I need a new ball joint at the right for my RS182 non Cup.
What's the best option?
1) Buy an genuine Renault ball joint.
2) Buy the right and left ball joint at the same time?
3) Buy a after market ball joint in A quality?
Who can give me the best option for quality!
  225 Cup & Williams
You can't buy a ball joint itself from Renault you need to buy the wishbone. Best bet is to go to a factors and buy lemforder items for both sides. Bolt size is 12mm if they ask.
  Clio 182
Thanx for all the information!!!
Is it possible that i've the screw om version en not the bolt on version?
There is no screw on version, i think you may be thinking about the track rod ends. If so again Lemforder are good.
I didnt notice the location, i think the TRW are ok i seen them mentioned before.
  Clio 182
Sorry, i made a (chupid)mistake.
I looked under the car again and it's not my ball joint.
I thought ball joint was the right name for the part.
My technical English is not good enough!
So i need the track rod ends.
Then i've still the same questions.
Can i us aftermarket and change only one site?
  330i. E30 Touring.
Aftermarket is fine, but you might as well change both sides.
Generally better regarded to do both.
No worries better to be sure.
Lemforder ones as said are good if they look like these then this the track rod end:-
http://www.eurocarparts.com/ecp/c/R...b6d0934e95c892fda1664dd6afe547c677ecb6&000349
http://www.eurocarparts.com/ecp/c/R...c7037f6e1e05afdee0480044a1e2604b70e70c&000349
They are the outer left & outer right ones needed, As said replace both and then get your Wheel Alignment/Tracking done.
  Clio 182
I ordered them left and right from Lemförder.
And after that i will do my Wheel Alignment/Tracking.
Thanks all!
