D
Dj Annihilation
Hi Guys
Managed to pretty much complete my sound upgrade. Changed Headunit, tackled the dash removal for tweeter change and everything else apart from a nice sub.
Followed the guide, pushed a screwdriver through the grommet on passenger side where the bonnet wire is, have to admit i prob made lots of holes, took ages, the wire would not go through, real tight gap, hopefully will be o.k, got it through in the end
My question is, is there any chance of that leaking? Reason i asked was on the old Zetec S the grommet was literally under the water drain for the windscreen and it was really exposed to wet, had to use sealant after to ensure safe. How about this one? to be honest it looks hidden away from any water etc? Just wanted to make sure as dont want any water leaks etc. Looks like there is sum wiring under the glove box that needs to stay dry lol!.
After that I am guessing i pull the plastic off down the sides and thread the wire down that side and the RCA's down drivers side? They literally pull off? OR are they fragile things ?
Louis
Louis
