Battery Change
MarcB
Car  Vw Golf
Has anyone changed the battery on a iPhone 7Plus ?
Watched a couple of videos on it but unsure what to do if the rubber stick tabs snap under the battery.
Any advice before I start this ?
If they snap, you just force the battery off and clean up sticky tabs afterwards.
Most of mine have snapped. You should get new ones with your new battery. Unless its some absolute cheap chinese crap.
Here’s a vid of one being taken apart.
Note if the tabs break then you just need to pry the battery away with something flat (around 1:40 of this video).
bought this one for the phone.
If the two pull tabs are snapped at the ends (which is quite common) then use a hair dryer or a lower powered heat gun on the back of the phone, on the underside of the battery and then use a wedge tool to lift the battery. The strips are just double sided tape and it's all the battery is held in by, just don't go bending the battery. If it isn't loose enough then use more heat mate.
