Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
On the battery negative the cable comes off to the battery tray but what earth's the battery tray ? Is it the bolts which hold the tray on or actually the tray itself ?
I have a earthing issue after fitting a gearbox to the 172.
Ah right, both 182 and 172s I've owned have had the earth bolted just above the top intake hose so I recon yours isn't where it should be.
Tray should work providing the bolt and area are clean to give a good connection as the tray is bolted to the chassis but I'd rather easy directly to the classis
