On the battery negative the cable comes off to the battery tray but what earth's the battery tray ? Is it the bolts which hold the tray on or actually the tray itself ?
I have a earthing issue after fitting a gearbox to the 172.
Ah right, both 182 and 172s I've owned have had the earth bolted just above the top intake hose so I recon yours isn't where it should be.
Tray should work providing the bolt and area are clean to give a good connection as the tray is bolted to the chassis but I'd rather easy directly to the classis
